Hi folks,
I fail to see the difference and also what crime I've comitted. Any clues?
Raiko
Can you upload a worksheet?
Mike, help me please. How did you do that? I'm still without insight ?!
In the last line, J[n+2,k, k was not subscripted.
The problem is with the k when locally defining Y, k was not defined as a subscript.
When it should have been:
Oh dear it must be monday.
Thank you for spotting that Mike!
Raiko
No problem.
It certainly is Monday, although a good way through it  .
Once again this problem highlighted Mathcad's useless error messages.
