Worksheet Converter in Mathcad Prime 8.0
MJ-StrEng
My Worksheet Converter in M-C Prime 8.0 for some unknown reason got grayed out and I cannot access it.
A note says "Worksheet converter is not installed. Run setup to add the installation."
Can somebody tell me how to do it. I tried to search for it but I could find nothing about running setup and reinstalling the Converter.
(To:MJ-StrEng)
When you install Prime you are given the option to additionally install the converter so you can convert worksheet from real Mathcad to Prime format.
The appropriate check box is by default unchecked and you have to check it if you want the converter to be installed. If you forgot to do so you can run the installation file again and have the converter installed.
See screenshot in this thread: https://community.ptc.com/t5/Mathcad/XMCD-MCD-Converter/m-p/871471/highlight/true#M206399
(To:MJ-StrEng)
Thanks for your help. My Converter works now.
