Wrapping long expression/equation
MJ-StrEng
How to wrap long expression to next line in Mathcad Prime?
In Mathcad 15 it is Ctrl+Enter, This is not working in M-C Prime.
8 REPLIES 8
Could not make it work, I tried various way with no result.
idahoan
(To:MJ-StrEng)
Try Ctrl+Shift+Enter
This is not working.
-MFra-
(To:MJ-StrEng)
Are you looking for these operators?
Yes, I am looking to use ENTER with these operators
(To:MJ-StrEng)
But PTC provides no means to change the keyboard shortcuts for the command. So you can't change them to use the Enter-key but you'll have to use the shortcuts PTC has implemented which are Ctrl Shift and the operator (+, -, * or /)
OK, it works! I do not mind an extra key stroke as long as it works.
Sequence/logic of wrapping the expression is funny looking but it is fine
with me as long as I know how to use it.
Thanks all,
MH
