Writing in Excel
fahmed-2
Writing in Excel
I am trying to export data from Mathcad to excel. I have attached the file as I did. I am facing two problems with this
1) It is saying the units are not compatible
2) It is making a new excel file named as "Collect data"
I do understand that since I have named the destination file as "Collect data" that is why it is doing that but I want to export data in an already made excel file such that Mathcad will only export data at that excel file in a specific sheet (i.e., Sheet2) and start from a specific cell (i.e., A19). It will also overwrite in the same location whenever a change is made in Mathcad. Please help me out.
Thank you,
Faisal
LucMeekes
(To:fahmed-2)
For one thing: You cannot export units to Excel, since Excel does not support/work with units: you cannot put a value with a unit in a cell AND have Excel understand that (natively).
If you divide your Psi Transposed by m that error message is (should be) gone.
The other thing:
Once that units error message is gone, the file is written. After I change "Sheet1!F19" to "Sheet2!F19" the same information is written to sheet 2 of the same excel workbook. I see no problems...
Note that Mathcad will recalculate any active expressions when a value that the expression depends on is changed. This is due to "automatic calculation". You can switch that off...
