about style names.
-MFra-
about style names.
Hello everyone!
I've a little problem with variables, namely: is it possible to delete a style name once defined and used, but no more useful and problematical? I think it isn't. Thank you in advance.
5 REPLIES 5
StuartBruff
(To:-MFra-)
F.M. wrote:
Hello everyone!
What version of Mathcad are you using?
Stuart
-MFra-
(To:StuartBruff)
Hello! I'm using the old student edition of MATHCAD14
RichardJ
(To:-MFra-)
You can delete the style name, but any text that has that style applied will stay the same. If you click on the text then the style name will just be blank.
-MFra-
(To:RichardJ)
Hello! My problem concerns variables. I had defined a new style "complex" in the position "user 3" in bold to highlight it in the worksheet. But, then, to simplify I abandoned this style and I changed the name of the style, in the same position "user 3" in "Variables". But MATHCAD, despite the variables have the same name, considers them different. So that it creates a lot of confusion and unexpected results increasing the amount of work to correct everything.
RichardJ
(To:-MFra-)
It's not like I make a habit of deleting style names, but as far as I can tell when you do that you only delete subsequent access to them. If you create a variable in a particular style, it stays in that style even if you delete the style name.
