Is there a function (action or formula some sort) so it can multiply(or sum it) elements (numbers) in generated table (rows)? (x and y is taken from the matrix(4 row, 1 col), i and j and k is indexes)
for exp.: in TR(xi,yj,zk) table - 1*1*1*1*1*1*1*1....=1,
Not sure what exactly you need.
Are you looking for something like shown below?
I would suggest that you create a question (discussion) not a document, as we can't provide files in the coments here and for some other reasons.
It would be helpful if you provide the output you are looking for made by hand so its more clear what you are after.
Or are you looking for something like this:
Anyway - whatever you are after, you will have to turn your results to vectors/matrices as you probably already have realized that you can't assign your results to variables ord do anything else with them.
For further questions please open a discussion/question.
