I have an error that : all evaluations resulted in either an error or a complex result
Do you can to help me for to display the graphics ?
Thank's
Are you sure you have f and j defined correctly?
Doesn't look right to me.
Mike
Becuase you haven't defined jf1.
Mike
I just declare jf1 and it's not good. That not to display !
Hello Julia,
you haven't defined jf. Also, MC doesn't display complex functions in 2 D plots. If you take the absolute value (see new MC sheet) it works
Raiko
Do you can to tell me if i agree.
See the file in attached
Your worksheet has a lot of problems. See attached for details.
Alan
