The first
not k(...), but k*(...)
The second
Just like this:
P.S. If you don't need the other post, that you issued short before this one, please delete it.
thank you very much
unfortunately, i cant get the same answer. can you give your file? LucMeekes
Luc has Mathcad 11 with other symbolic engine.
Sure:
P.S. Note that Mathcad 11 (symbolic engine: Maple) will give generally a single answer, even if multiple/periodic answers exist.
The example of Valery shows that Mathcad 15 (symbolic engine: Mupad) may give the multiple/periodic answer to such problems.
Mathcad 11?
Mathcad 15
thanks guys, you are always so helpful.
