array
taylor35
array
Im new to MathCad and im trying to find the fourth roots of -16j. I typed this in exactly like this and mathcad said that I have to have the -16 in an array. Any help would be great thanks
7 REPLIES 7
Perhaps you could post the sheet with the problem. -16j is a perfectly valid number (pure imaginary) and does not need any arrays. I suspect that that is not exactly what you typed. Perhaps you have attempted to define j (not a good idea) and used multiplication (rather than a scale modifier). Can't really tell without the sheet with your error.
__________________
� � � � Tom Gutman
See attached for a couple of options.
stv
Instead of tweaking MathCad, why not just stick to fundamental algebra or calculus in polar coordinates?
The other worksheet is OK, but one more root can be found, and here a worksheet with plenty of confusion over angles, signs, trig identities, etc. The basic rule is that the root is a quantity that multiplied by itself n-times is found by dividing the angle by n, and extracting the n-th root of the amplitude.
Different roots are obtained from how the Argand diagram is employed. Some are algebraic, others complex plane roots.
On 2/14/2010 7:30:45 PM, taylor35 wrote:
>to find the fourth
>roots of -16j.
May by so:
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Sorry for my english forth is 4-th not 5-th!
Val
