I want to remove mathcad from my old computer to install it on a new one. How can I do that.
Depends on where your license is located.
If on a server, you don't need to do anything, except load MathCad and configure the new computer to read the existing license.
If the license is local, you will need to use the license tools to transfer the license to the new computer's IP address, then install MathCad.
Yes
License assets
Advanced, enter your old host ID
Search
Move License
1. Use "Reconfigure Software Licenses" option from a PTC's site: http://www.ptc.com/appserver/lm/rsl/reconfig.jsp
Or
2. Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
