definite integral with DXF input
TerryKoen
I am trying to find stress levels on a safety pin. I import the DXF file and extract the end points of the lines on layer 1 into a matrix. Then evaluate the points that are cantilevered. The The integral sort of works but I can not get it to plot. Any help would be appreciated.
TOK
Vectors are not just lists of numbers, they are a mathematical entity. Some operations on vectors are applied individually to each element, others work on the vector as a whole. And some are simply not allowed.
In particular, you cannot use a vector as a limit for an integral. The limit must be a number. If a function uses an argument as an integration limit, only scalar values can be passed for that argument. To evaluate the function at a series of values stored in a vector you must explicity vectorize the function call. That causes the function to be evaluated separately for each element of the vector rather than for the vector as a single value.
Integrals are comparatively slow. They involve multiple evaluations of the integrand in order to estimate the actual integral. If the integrand is somethat that is slow to evaluate (say, an integral) this can become very noticeable. Try to nest integrals a few times and things quickly get unbearably slow. Even with fast machines.
When you want te evaluate an integral for a large number of values of its limit, it ismuch faster to set it up as a differential equation and then solve that. For multiple integrals you can set up a system of differential equations and get results quickly.
__________________
� � � � Tom Gutman
Thanks Tom. You are right it takers for ever to evaluate the last integral. I'll rewrite as differentials
TOK
