export data
fahmed-2
export data
Is there a way to export data from Mathcad to excel. My Mathcad version is prime 4.0.
Thank you,
Faisal
5 REPLIES 5
LucMeekes
(To:fahmed-2)
You can use the function WRITECSV (look it up the help). It will write your data to a ,csv (Comma Separated Values) file, which you can read in with any excel.
LucMeekes
(To:fahmed-2)
Then there's also WRITEEXCEL (look that up in the help as well). It will write your data into an existing Excel sheet at a certain location.
LucMeekes
(To:fahmed-2)
And there is WRITEFILE (... help...) which will (over)write your data to a (new) Excel file.
fahmed-2
(To:LucMeekes)
I was trying to export the data from Mathcad to an already made excel file but it is not letting me to. It lets me to a new file but not an existing one
Your command:
From Help:
Your arguments are in the wrong order. I would leave out the row and column values and the !B5  and see whar happens
