The data import wizard doesn't find a name. It uses a name that you provide, one way or another. If you want to know the name, just provide it in a way that you can remember and find. If the issue is the use of the wizard's browse facility, you can accomplish that using Xavier's file browsing scripts (based on list box selections).
__________________
� � � � Tom Gutman
