function values
SFares
function values
if i have a range, for example, h=2,2.2..8 , and a function of "h", f(h), how can i make mathcad display both "h" and the corresponding function value in a table format? Thanks!
(To:SFares)
Maybe something like the attached?
(To:SFares)
SFares
(To:SFares)
Thanks a lot!
(To:SFares)
You are welcome.
Please keep in mind the difference between range variable and vectors - its not the same. The sheet of mine provided first h as range, then as vector.
For further information about ranges vs. vector you may lookup this:
http://www.ptc.com/WCMS/files/131949/en/Range_Variables_Vs._Vectors_in_Mathcad.pdf
