Hi, Any one can help me to correct my mathermatical expression using MATH CAD prime 3.0. I attached the spreadsheet and I need to get an answer for the element in Array if the element is Compact, semi or slender.
Please resend to me the file with your correct mathematical formulas.
Thank you problem solved !
Here is another approach using vectorization.
Like so?
got it vectorization ! Thanks
