if we use lengthy formulas, it went outside the page frame. anybody please help me if there is any possibility to reduce formula length
This is possible:
Position the cursor to a point where you want the split (it has to be a + operator).
delete the + to leave a place-holder then press <CTRL><Enter>
Hello ballaji,
the short answer is: you don't!
Unforftunately Mathcad, and notably Mathcad Prime, don't automatically handle euqartion display. So you're left to yout own devices.
I suggest splitting up lengthy equations into sub units and add them up later to a master equation.
E.g. f(x)=x2 +a*x3 -c
g(x)=d*x4+e^(x/55)+c+x2
d(x)=f(x)+g(x)
Raiko
Sorry I forgot to mention which version of Mathcad I am using . I am using MATHCAD 15. is there any possibility to control the length of lengthy equations in MATHCAD 15
It is sometimes important to write out the complete equation. Adding two equations is just for the mechanics.
This is possible:
thank for your reply, its working fine
