how to input "/" in mathcad prime 3.0
胜王
3-Newcomer
I want  to input "/" in Mathcad Prime 3.0,such as 3 m/s,the "/" also can be calculated in my document,is it possible?
Do it please in Mathcad 15 and convert the file into Mathcad Prime!
Or use my sheet in attach!
(To:胜王)
If what Valery had shown is what you are looking for - you can easily create on your own:
1) Type double quotes and inside type the expression with the / sign
2) Delete the quotes
3) label the new expression as unit (just for consistency)
4) Follow the expression with a colon and add the meaning of the expression, so you can use it correctly in your calculations
Werner
