how to solve these equations::plz help
  • September 24, 2012
  • 1541 views
Dear mathcad fans,
I would like to know how to solve these equations ?
x1 + y1=6
x2 + y2=9
x1 + x2 =8
y1 + y2 =7
Any idea how to get that?
Thank you in advance.
Best answer by ptc-4287700
Mr. emad habeeb,
There is no guessing of the correct values.
It is solved using the Mathcad's Matrix method.
Just try doing it.
Insert a matrix of 4 row and 1 column. Type the equation. x1+y1 (ctrl+=)6 ....complete the matrix.
After completing the matrix, use the symbolic keyword toolbar and click solve.
again insert the matrix of 4 row and 1 column and write the values x1, x2....etc.
You will finally get what is shown above.
thanks Valery for your reply, but can you tell me: what the method is used to solve these equations?or you just guessed the correct values.
Mr. emad habeeb,
Just try doing it.
