loop for
Prasetyo
loop for
Hi Guys,
I am a new user for mathcad 15. I need your help. I am trying to make iteration using 'for'. Unfortunatelya when I pressed keystrokes [ctrl]["], the oprator 'for' not coming out. Did I make a mistake? or is there another way to use the 'for' operator?
Thank you very much for your kind help.
prasetyo
5 REPLIES 5
Go to view, toolbars, and select the programming toolbar. The 'For' command is in there.
Mike
thanks a lot
VladimirN
(To:Prasetyo)
Hello!
Other way to insert a loop "for" is a combination of keys: Ctrl + Shift + "
Do you know this properties of the for loop?
Nice simple examples Valery, I suggest the thread creator look through the help or quicksheets.
Mike
