Hello there!
Can someone convert a .mcd to a .mxcd
I need to open a .mcd file in Mathcad Prime 5.0.0 and it does not work.
Tahank you!
You need to install Mathcad 15 on the same PC as Prime in order for the converter to be enabled.
You can use the very same license file that you used for Prime to license mathcad 15.
For more info, see here: https://community.ptc.com/t5/PTC-Mathcad-Installation/XMCD-MCD-Converter/m-p/716266#M294
Upload your worksheet here.
