How do I minimize a function of 2 variables?
By using the Minimize function?
To give a more specific answer than that we would require a more specific question.
example:
Option 3:
Note: this may minimize more than just your function ![]()
Is there anything wrong with using the built-in help and looking at the examples in the appropriate quicksheets?
Which information is it you are you missing there?
@ Mark Gase: As you use no constraints you can use Minimize/Maximize without a solve block and so you can omit the "given".
Werner
Good point. I was just throwing something together quickly.
A function with 3 arguments and a symbolic solution
