"Value cannot be null. Parameter name: pUnk"
jc-4
Please see screenshot below and help me get the items in the Component Wizard to show up again.
Joe
10 REPLIES 10
Fred_Kohlhepp
23-Emerald I
(To:jc-4)
I a bit confused.  Your screen shot looks like you've got an EXCEL sheet imbedded; I get the component wizard window if I'm inserting a new component.
If you have the this
in a sheet already try this:
  • right-click on the component.  You should get a dialog with
                                 "add input variable"
                                 "add output variable"
                                 "properties"
   and a bunch of other options
This should let you define your inputs
VladimirN
(To:jc-4)
But where is your Mathcad worksheet with this error?
jc-4
(To:VladimirN)
1.png@
jc-4
(To:jc-4)
This is the mathcad program that shows the error.
Please advise what to do about it.
Joe
Fred_Kohlhepp
23-Emerald I
(To:jc-4)
When I open this file the variables report the correct numbers and 176 rows.  I don't see the problem. . .
right-click gets me this:
VladimirN
(To:jc-4)
There is no any error in Mathcad 15 M045 with your example worksheet. What version of Mathcad are you using?
jc-4
(To:VladimirN)
Hi guys,
The thing I'm missing is the stuff that I see in the Component Wizard.  If you look at my very first post, supposedly all those items "Matlab, Excel...etc" should show up in Component Wizard, but I don't see any of those.
You don't have problem because your component wizard shows Excel , but mine doesn't.
How to fix this?
Joe
RichardJ
(To:jc-4)
My guess is that if you insert a 3D graph you will also have a problem. Similarly if you insert a control (such as a list box).
VladimirN
(To:jc-4)
RichardJ
(To:jc-4)
Repair your Mathcad installation.
