Hi everyone my name is jimmy from Mexico im student researcher my major is electromechanical engineer, i have a project for evaluation of PV modules, and one of my objectives is too use data-sheet information with 4 parameters Voc,Isc,Vmp,Imp from the PV module to extract another parameters (a,Iph,Io,Rs,Rp) that not included in the data-sheet. For that im using a five parameter model to solve that problem, im using the solve block (Given,Find) for a nonlinear systems, the method im using is the conjugate gradient. im attaching my file and you will see all the equations that i use, my problems is that when i put the solve command an error display appear saying that some variable is undefined and i check all the file to see what would be the problem and when i use the track error option put me in the first formula the saying that Iph is undefined. i will really appreciated if you can help me because im new on this software
Best regards to the PTC community.
the five equations that i put it is from the model. It supposed works solving with the conjugated gradients method with mathcad solve block (Find,Given).
Nevertheless iot seems that Alan is right and you are missing a fifth equation. Or in other words, there is more you can wish.
Being an underdetermined system would perfectly explain the different results achieved with different methods.
Of course this does not mean that I think that there is mistake in the De Soto model, but maybe it needs some further inverstigation from your side.
What I spotted on first glance is that
1) Rs has no guess value
2) Most/All of your five functions don't use all parameters, so these obesolete parameters should be omitted
hi Werner i will check carefully all ur points in my file thanks for the comments.
Unfortunately changing it does not help ;-(
if there any other way to solve it?
Think it should work that way. I am not sure what the problem is.
ok Man i ll try to see what should be the problem thx for everything best regards.
Error messages with solve blocks are worse than awful. In fact the one you got is the only one a solve block would throw, no matter what the error ist. Usually Trace Error helps a bit, but not in your case.
Neverthess I found that if I provide a guess value for Rs and if I disable the equation with h(), I get a solution - whatever that may mean. You may want to double check your model.
yes Werner i do the same and only fails when i enable the eq h() , but the values are not the correct one and i also check the articule of the model and it seems to not have a problem ;(
At least the error is now more meanigful - if you use trace error it says that the no solution was found and suggested to change TOL/CTOL (which didn't help) or provide different guess values. So if your equations are correct try the correct solution values as guess values to see if it would come to an solution.
The five reference parameters (a, Io, Iph, Rs, and Rp) can be
obtained by simultaneously solving Eq. (7) through Eq.
(11) using the Mathcad solve block (Given …. Find) and
by implementing the method of Conjugate Gradients.
The necessary guess values are easily determined as
follows:
The value Iph is approximately equal to the value of Isc
which can be used as a good guess value. Usually, the diode quality factor 1 ≤ a ≤ 1.5 . The reverse saturation current Io guess value can be obtained using the following equation.
A guess value for Rp can be obtained by evaluating Eq. 2 at
open circuit condition. Also, a guess value for Rs can be
obtained by evaluating Eq. 2 at short circuit condition and
assuming Rp→ ∞
The factor Io is at the wrong position in the first three equations.
Not sure about the last two equations
could you explain me with more details Werner cuz i dont see the problem
In all three equations there is an exponential function followed by "-1". Both should be multiplied by Io but in your sheet only the exponential expression is multiplied by Io.
Unfortunately changing it does not help in finding a solution so there may be an error in the last two equations.
i check the last comments and checking the model i found the derivates and the last equation was not right, but i changing the values and put the correct ones but didnt works too.
What is f_Imp and f_Vmp.
And whats the connex of the last two equ and to the two expression given in the literature you cited?
Plotting theP–V andI–V curves requires solving (2) for I∈[0,Isc,n] and V∈[0,Voc,n]. Equation (2) does not have
a direct solution because I=f(V,I) and V=f(I,V).This transcendental equation must be solved by a numerical method and this imposes no difficulty.
I = f (I , V ) .........................................(14)
where f (I, V ) is the right side. By differentiating (14):
doing the same analogy for dV/dI we got the dP/dI.
this came from the reference of the model paper
Solution seems to be mostly working; but with the use of units one error has been noted in the definition of Rs.
Depending on whether you choose to use units or not the symbloic solver may (or may not) give a sensible answer.
The final solve block did not converge for "Find" but does work with "Minerr"
Hope this helps
Andy
Your sheet works for me using Find(), too, and comes up with the same solutions.
I found that Jaime's sheet would find a solution using Find() if Find() is evaluated symbolically. But the solution differs from yours! Its noticeable in your solution that Iph doesn't change.
Hi Werner,
Minerr is giving a lower ERR value, but the Find solution definitely appears better from the Io current value returned.
An understanding of the meaning of the equations is required to say what is correct and / or meaningful.
Regards
Andy
Maybe, but in your sheet we get the same solutions using Find and MinErr (symbolic eval is not possible ere because of the units).
So I wonder if you have changed something else other than adding units and correcting the definition of Rs (which at the end only affects slightly the initial guess value for Rs).
I just tried and deleted all units in your sheet and it still evaluates using Find() - so obviously something else was changed, too.
This is what I get with your sheet and symbolic eval (numeric will give the same results as with units). Notice especially the difference in Io and a!
And the values are different from what I got with Jaimes's sheet and symbolic eval.
I have no explanation.
I think that it might be another case for the MathCad Mad House ...
I've narrowed the search down to the Find statement , but I can't spot the difference... :-))
Obviously much dependent on the algorithm chosen (LM, CG)
Wonder what algorithm the symbolic eval choses - should not be an approximating numerical algorithm.
Wouldn't say that the results from the symbolic are best while I think they should be.
In your comparison you have to pull down the functions you evaluate a bit so the correct values are taken
hi Werner and Andy let me put the correct answer from the model paper
thats the values from each parameter i use the last revision of my file and seems only working with the LM algorithm
Usually it is said the LM is the to be preferred algorithm.
Maybe you can come closer to the published values by changing the values for TOL and CTOL.
Anyway your solve block remains a puzzle
i found something if i change the guess value of a wich is the diode factor, its afects with all the system. maybe i need to find the correct guess value of this parameter to find the correct solution.
Selection of guess values can in some cases influence the solution quite a lot. So what happens if you chose a:=1.3?
i random values between the range of 1 to 1.5 , and i found that the most approach correct values is between 1.3 and 1.4 and changing the values for TOL and CTOL. but im still working on it
Seems to me you don't have 5 independent equations with which to find the five unknowns. These last two:
provide basically the same information in a slightly different form (substitute one into the other and you get a trivial identity). I think you need a fifth, independent condition.
Alan
Alan
Hi Alan thanks for your comments, im using this method for my project becuse i want to use it as a predicted method , the five equations that i put it is from the model. It supposed works solving with the conjugated gradients method with mathcad solve block (Find,Given).
