switched return
Efried
7-Bedrock
switched return
before running to deep into the obvious wrong error message, allow me to ask wether is possible with mathcad 14:
if condition ==true
return vector of elements divided by their different units
else
return another vector with another size and other orininal units (also divided by them removing them)
thanks
gerfried
StuartBruff
23-Emerald V
(To:Efried)
if condition ==true
else
thanks
gerfried
Yes ... provided I've understood the question. See attached for an example.
Stuart
Fred_Kohlhepp
23-Emerald I
(To:Efried)
if condition ==true
else
thanks
gerfried
Before you get too far into this, look up the UnitsOf() function. While it can (and has) caused much anguish and many errors, x/(UnitsOf(x) will render a quantity that has no units and is numerically the correct value of x expressed in default units. Keeping track of what the units SHOULD be will still be problematic.
Can you provide a worksheet indicating what your after, will save people guessing.
Mike
