On 8/12/2009 4:30:08 AM, stuartafbruff wrote:
>On 8/12/2009 2:19:16 AM, jmG wrote:
>== My main point (other collabs too) was
>that Mathcad does not distinguish
>decorations neither in the variable name
>or in the argument. Mathcad only
>recognizes what is executable. If it
>would be otherwise, the confusion would
>be total and rendering work sheets not
>interpretable, also considering as many
>decorative styles as there would be
>users.
>Mathcad does distinguish between
>'decorations' in the sense that the math
>style name forms part of the variable
>name.
>The xmcd file defines the style at the
>beginning of the worksheet, eg mathStyle
>name="User 7" font-family="Tahoma"
>font-charset="0" font-size="12"
>font-weight="bold" font-style="italic"
>underline="false"/>
>The xmcd file defines the variables in
>the region section, eg ml:id
>xml:space="preserve"
>font="10">x >"ml:id" bound the variable name and
>"font=" identifies which math style
>applies.
>In Mathcad 7, the equivalents would be
>.CMD DEFINE_FONTSTYLE_NAME fontID=10
>name=User^7
>{10:x}
>Hence validating the assertion that the
>math style forms part of a variable
>name.
>The main problem with the appearance of
>italics is due to the limitations of the
>Mathcad screen render coupled to what,
>for many, is still a fairly coarse
>display resolution - it's the
>'staggering' of the pixels in the italic
>lines that creates the problem.
>Try looking at the attached worksheet in
>150% or 200% zoom - the fonts look much
>better, although still a little bit
>jagged (look at the radical sign).
>Better yet, print it out - the italics
>look fine.
>Or export it to pdf, Adobe Reader does a
>better job of smoothing the lines on
>screen than Mathcad does. Zoom to 100%,
>150% and 200% to see the difference.
>The attached worksheet also gives the
>Latex program that generated the text in
>the 'image' that I used as the basis for
>the 'Mathcad' content. (note default
>equation text is italic, \rm = roman and
>\bf = bold font). A Latex file is
>'simply' a means of telling a Latex
>processor what to draw and is notionally
>equivalent to postscript or pdf in that
>sense.
>The functional impact on Mathcad by
>providing Latex output would be about
>zero.
>Stuart
_______________________
Thanks for your interest Stuart,
Your Latex coding, codes directly in ORIGINLAB. It codes on a special template as well as on the plotting graphic, but I didn't use for at least 8 years and my use was limited to better displays in the graphic. Back to the WRI fonts, they are those specials characters/symbols particular to Mathematica... their interest as math equation is zero absolute 0 ! The AMSF are free, maybe worth a try for the originator... and my point here is about using them "as Mathcad executable" as far as Mathcad is receptive and if they are smoothed and if they can be coded.
Nothing to add on my part. The originator wanted "Mathcad italic", Mathcad has italic but it does not have italic because the Windows italic fonts are crappy enough to scare flies. As a byside remark, the Mathcad parentheses go by the the Verdana, i.e: for colored brackets define a user7 dunmmy variable Verdana and you will get all the brackets in color, just very distinctive.
![](/upload/Italic05.gif)
jmG
