unable to view network drives or folders openning file in MathCAD 15
PenksikS
3-Newcomer
Can anyone suggest why Mathcad 15 does not see network drives properly mapped in Windows 10? CREO has no problem with it.
if any program can't see network drives then it is probably launched under different user account. Check properties of Mathcad shortcut.
Martin Hanák
6 REPLIES 6
What happens if you try to open a Mathcad 15 file on your network drive from and explorer window?
It works OK, drives are properly mapped in Windows.
LucMeekes
(To:PenksikS)
Consider that Mathcad is about 10 years old and a 32-bit application...
Did you upgrade to the latest release of Mathcad 15?
Yes it is upgraded to MathCAD 15 M050
Martin Hanák
Thanks a lot Martin! It is exactly what happened. On default after installation MathCAD was launched with "Run as an administrator" options ON. In that case all network drives were disabled.
