On 8/24/2009 7:14:29 PM, radair wrote:
>Also in regards to your other
>note, press Ctrl Alt Shift Q,
>and you�ll see a panel where
>you can change the colors.
>This is internal right now,
>but I am trying to make it
>available to users.
Everyone needs to be aware that these settings are "sticky". If you close and reopen Prime they are not reset to the defaults. I have played around with the colors, but that's all. If you change anything else, write down the original settings first!
Richard
