I got advice to use "vectorization"
But I wonder something.
I saw the book and I knew that "vectorization" is just possible to calculate about same raw and column.
But I need to know total calcuation values.
For example
a=0,1,2,3,4,5 b=1,2,3,4,5
y=ax*b
if I caculate by using "range variable", I get total calcualtion values. in case
<a=0,b=1> ,<a=0, b=2>.....<a=0,b=5>
<a=1,b=1>, <a=1, b=2>.....<a=1, b=5>
<a=5, b=1>, <a=5, b=2>......<a=5, b=5>
I want to get values following.
I couldn't have used "vector" because I thought that I couldn't get it.
I want to get values look like "range variable" because I need to total values when I did iteration calculation.
How to do what you want is explained in detail in the sheet I sent and various methods are provided for you to chose from. The function and vector variables used in the sheet are different from those given by you now because I used what you had provided in the last thread.
All methods given will calculate all combinations of values from the two vectors - the difference is the way those values are arranged. I also provided ways to arrange all values in a single column vector similar to what the result looks like when you use ranges, but I doubt that this data representation is the most useful. But if you really insist on it - its there.
I now can't attach my file because I need to clean my file.
Yes, the last sheet you attached was quite a mess.
The worksheet, pls!
Vectors are often faster and easier. For some things you need indices.
thank you. I try to appy my work !
And I have a question.
If I use "nested array", Can i get values that I want to get?
How do you think?
How do you think?
??? I think you will have to be more precise on what you intend to do to get an adequate answer.
Isn't this basically the very same question you already asked a week ago here: http://communities.ptc.com/message/262848#262848
Fred answered and as you never mark a question as being answered (which is a bit irritating) we have to assume that you got what you want when you don't come back again as so often.
Thank you to effort to help me.
So I try to explain what I want and why I do it
1. I need to calculate interation in case of changing variable such as a, a', r or mu.
okay I got it.
thank you for condideration
I could success to express theta look like "range variable"
But I can't get "alpa"
I guess the reason why I can't get values is due to "beta"
I got error. error said me that the unit is not compatible.
so I don't know which it is wrong.
I'm beginning to believe that you are leading us on; you keep making the same errors, failing to grasp the same concepts.
Read the discussions in the help files about units, range variables, vectors, etc.; and built yourself little demosstration programs until you understand how this software works.
Okay. I got it.
Please don't cross post and ask the same question in two different threads.
http://communities.ptc.com/message/263952#263952
Moreover I would second what Fred wrote!
I am sorry. I forgot to delete my question.
