x-y plot with table (trace color)
ptc-3772358
I have two tables, each with 3 columns of data points. I created an X-Y plot with the tables. The problem I now have is that all 3 plotted lines are same color. Apparently MCAD treats them as one trace. When i go into graph properties to change their individual color i can't - all i can do is change all of their colors together.
Anyone know a way around this?
thanks,
russ
RichardJ
(To:ptc-3772358)
If you plot the table as a matrix then each column will be a separate trace, but all traces will have the same properties. If you want them to have different properties you have to split the columns out using the column operator, and plot them individually.
Thanks Richard - that is the solution!
best regards,
russ
Hello!
Please attach your Mathcad worksheeet (select "Use advanced editor" in the right corner).
