Hello Community,
My xmcd-file doesnt open anymore. Mathcad shows me only the message, that the file is destroyed. The error message give no further information what is wrong with the file. See the screen shot attached.
I am using Mathcad 15.
What do I need to do, to be able to use the file again?
Thank you very much for your help in advance.
Harald
The contents of the file are HTML, not XML (basically, it's a web page). This cannot be converted back to a Mathcad file.
Can you post the file here?
For the future - do not forget about the "Autosave" option (in main menu select "Tools" -> "Preferences" -> "Save"):
Hello Richard,
Hello Vladimir,
Thank you for the help.
The good thing is, I have a printout of my homework in Mathcad. So I need only type it again.
Best wishes,
Harald
