xml schemas
AlvaroDíaz
9-Granite
xml schemas
I traying to understand mathcad's xml schemas, but can't download it. Web directions for a document done in mathcad 13 have:
worksheet version="2.0.2" xmlns="http://schemas.mathsoft.com/worksheet20"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ws="http://schemas.mathsoft.com/worksheet20"
xmlns:ml="http://schemas.mathsoft.com/math20"
xmlns:u="http://schemas.mathsoft.com/units10"
xmlns:p="http://schemas.mathsoft.com/provenance10"
metadata
generator
Mathcad Professional 13.0
/generator
Directions are broken, send me to ptc document not found page. Are those documents on the web or only in the mathcad 13 local machine folder?
Regards. Alvaro.
PhilipOakley
(To:AlvaroDíaz)
Ahh, you've been fooled, like I was fooled by the
namespace descriptor. It looks like a web address
but is actually just a method of creating a
(hopefully) unique long name for the namespace.
It isn't a read address ! ! ! !
You will however find the schemas 'hidden' in the
directory 'schemas' of you mathcad installation.
(If you search the forum, you'll find mona giving me
the same answer 😉
The real question though, is what do you want to do
with them... ?
I think one can write XSLT code that will convert
mathcad xml (xmcd) into real code, particularly
matlab (especially if you use ORIGIN =1 😉
Philip Oakley
PhilipOakley
(To:AlvaroDíaz)
the same answer 😉
with them... ?
Philip Oakley
On 12/16/2009 6:40:51 PM, philipoakley wrote:
>Ahh, you've been fooled, like I was fooled by the namespace descriptor. It looks like a web address but is actually just a method of creating a (hopefully) unique long name for the namespace.
Programmers have amazing methods with nothing amazing results.
But the first is an address:
>You will however find the schemas 'hidden' in the directory 'schemas' of you mathcad installation.
I want to start with the old versions, so, needed to see a mathcad 12 & 13 installation.
>the same answer 😉
I don't search, go to try it.
>with them... ?
Combine mathcad and access: a database with mathcad formulas.
>code,
I need examples to start 🙂
>particularly matlab (especially if you use ORIGIN =1 😉
Well ... such effort must to have a recompense in another life ... or another program.
Regards. Alvaro.
