Accessing Kepserver tag from external code
Sri1
There is requirement, that in a particular condition a Tag's value in the Kepserver has to be changed.
I can detect that particular condition externally (though nodejs service), now how do I access this Kepserver tag from my nodejs service.
Is there any API that Kepserver provides to connect to its device tags and alter.
Please suggest.
Sri1
AndrewBlack
(To:Sri1)
Greetings,
KEPServer has the ability to enable our Config API to make changes to channel/device/tag properties, but not the tag values. You would need to use some sort of client application to make those changes, Kepware does not have a client that is provided apart from the OPC Quick client, which is just a test tool
Kind Regards,
Andrew Black
AndrewBlack
(To:Sri1)
Greetings,
Kind Regards,
Andrew Black
slangley
23-Emerald II
(To:Sri1)
Hi @Sri1.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
