Is there a way to clear the KPI calculations just like they do after a shift change? I am trying to find the same service you use for shift change so that I can run that same code when we do a SKU change. This way it will reset the APT and PBT time info. Please direct me which service clears those APT and PBT or how I can change them to zero.
thanks
Have you looked at the help center? "Configuring KPI Calculation": https://support.ptc.com/help/thingworx_apps/r8.5/en/index.html#page/thingworx_apps%2FThingWorxAppsCust%2Fcustomizing_kpis.html%23
Hi @mpaisley90
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
