I have the same problem and basically the same configuration as showed. I'm able to see the data on the OPC quick client, I have "logical Non-Blocking" under protocol mode.
There's a message displaying "Error pushing property updates to thing" not sure if it's something related to it,
Hope you can help me,
Thank you,
Hi @chavarria.
If the previous response helped to answer your question, please mark it as the Accepted Solution for the benefit of others on the community. If you still need assistance, please provide additional information.
--Sharon
