Connect CWC to Thingworx server
KSM
Hi all,
I am trying to connect/Integrate  Thingworx application "connected work cell" CWC to the Thingworx server 9.3.0. So anybody could provide the solution.
KSM
1 ACCEPTED SOLUTION
mstarnaud
(To:KSM)
Hi KSM
CWC is not compatible with Thingworx 9.3.0, you would need to upgrade your Thingworx a bit. Choices are :
- CWC 9.5.0, released last week, works with Thingworx 9.5.0. The CWC installation documentation for 9.5.0 is here.
- CWC 3.1.1 works with Thingworx 9.3.9. The CWC installation documentation for 3.1.1 is here.
- CWC 3.1.0 works with Thingworx 9.3.5. The CWC installation documentation for 3.1.0 is here.
The installation process essentially looks like this :
- Must already have Thingworx installed, the requirements are explained in the documentation.
- Download the CWC Zip file from the PTC download page, in the Thingworx Foundation group.
- Run the EXE installer, it will ask you many connection questions, like ask for your Thingworx URL and SQL connection.
- Fill an Excel data import tool, with configurations like the equipment types.
- A few actions are required in the Thingworx Composer UI, to finish configuring the equipment types.
- Finish the configuration in the CWC UI (equipments, smart tools, reasons, work instructions & steps, etc.) and start using it.
This should be explained in detail in the documentation.
2 REPLIES 2
VladimirN
24-Ruby II
(To:KSM)
mstarnaud
(To:KSM)
Hi KSM
