Error importing Demo Factory DataSet
olatz
I have a Thingworx 8.3 instance on Ubuntu working and added Manufacturing Apps 8.3.0. The proccess of importing the neccesary extensions went OK.
I am trying to import the Dataset "DemoFactoryDataSet.zip" from the guide "Connect Factory Assests Using Controls Advisor (Guide 1)" but the following errors are shown:
ErrorCode(af70920f-afd8-4700-9438-a4f0a78b5bdd), Cause(com.thingworx.contentmanagement.ImportExportAsyncHelper.<init>(Lcom/thingworx/security/context/SecurityContext;Lcom/thingworx/contentmanagement/ImportExportAsyncHelper$TaskType;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;)V), Reason(A Java method definition was not found at runtime.), Possible Resolutions([1]=Verify that you are compiling against and running against the same Jar and/or class definition versions., [2]=Verify that you have including the correct version of the Jar file in your Extension manifest file as a Jar Resource.)
[context: com.thingworx.webservices.context.HttpExecutionContext@23074eaa][message: Unable to Invoke Service ImportConfiguration on PTC.Factory.Administration.ImportExportUtils : com.thingworx.contentmanagement.ImportExportAsyncHelper.<init>(Lcom/thingworx/security/context/SecurityContext;Lcom/thingworx/contentmanagement/ImportExportAsyncHelper$TaskType;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;)V]
I know that the guide is written to work on a Manufacturing Apps 8.4.0 but I supposed that it would work with a lower version (in my case is 8.3 because is the only version that I can download from "PTC Software Download Page").
Any help or idea?
Thanks.
1 ACCEPTED SOLUTION
olatz
(To:olatz)
Finally I had reinstalled the server with the verision 8.4.3.
2 REPLIES 2
hchanana
(To:olatz)
Hi @olatz ,
Please try downloading and importing demodata from below url.
https://learningconnector.ptc.com/content/tut-5593/learning-workshop-1-configure-manufacturing-data-set-and-simulator-for-the-thingworx-manufacturing-a
This bundle contains pdf guide also which provides the instructions for installing demo data.
Himanshu
olatz
(To:olatz)
