Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hey,
atm we are planning to build a worker guidance PoC with ThingWorx and Operator Advisor.
I'm looking for a tutorial/course at PTC academy/Youtube etc. on how to install & use the Operator Advisor with ThingWorx properly.
1) Does anybody of you have a good recommendation?
2) Is it a good idea to implement a worker guidance with Operator Advisor and Thingworx? Any tips?
Thank you very much
Phid
Is
Operator Advisor Help Center can be opened as below.
1. open https://www.ptc.com/en/support/help
2. select thingworx
3. select thingworx Operator Advisor 8.5
https://support.ptc.com/help/thingworx_operator_advisor/r8.5/en/
Inside the HC, there are several examples for user to refer to.
please check if above is what you need.
2. select thingworx
Hi @PD_9717258.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
