Is there a way to set it to https (SSL) when installing ManufacturingApp version 8.4?
xiaoqw
Re:  post
hi, May I know whether your SSL certificate is successful or not?
I also follow this instruction but part B code cannot find in the PTC_Servlet_Engine/server.xml file and SSL is not successful.
1 ACCEPTED SOLUTION
Hi @xiaoqw ,
You need to make changes in your tomcat_dir/bin/server.xml of your tomcat server on which thingworx platform is hosted.
Please refer below article which contains detailed description of SSL setup
https://www.ptc.com/en/support/article?n=CS193947
Himanshu
2 REPLIES 2
Hi @xiaoqw ,
Himanshu
slangley
23-Emerald II
(To:hchanana)
Hi @xiaoqw.
If the response provided by @hchanana answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
