MTConnect Stream XML Read Data Error
HM_9920528
2-Explorer
Hello Everyone,
We have DMG Mori machine it streams data with MTConnect 1.3.0.17 we can reach it from browser. We add it KepserverEx and open Quick Client it gaves that error down below. Also we have Okuma MTConnect Stream which same version 1.3.0.17 with it works well.
Error MTConnect Client Read for the data items 'currentRunTime,program1' on device 'MTCONNECT.HUT191' failed. Reason: 'XML Validation Error: 'INVALID_XPATH' violates enumeration constraint of 'UNAUTHORIZED NO_DEVICE OUT_OF_RANGE TOO_MANY INVALID_URI INVALID_REQUEST INTERNAL_ERROR INVALID_PATH UNSUPPORTED ASSET_NOT_FOUND'.The attribute 'errorCode' with value 'INVALID_XPATH' failed to parse.'.
Greetings,
Please see the knowledgebase article in the following link as I believe it will resolve the issue you have encountered:
https://www.ptc.com/en/support/article/CS286359
You can use your my kepware credential to login and view the article. If you do not have a my kepware account, you can sign up here:
https://my.kepware.com/s/login/
Greetings,
slangley
(To:HM_9920528)
Hi @HM_9920528.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
