Manufacturing Apps assets can't connect Kepware
ljam
9-Granite
I installed manufacturing apps trial and import simulation data succesfully and I did 2 guides about manufacturing apps, Controls and Asset advisor but now I have a problem because Kepware is connected with Thingworx but I can't see data simulation in my assets. I checked log and I saw this error:
An Invalid Property Value Was Sent To [PTC.MfgSegment.Kepware_Simulator-GW Property: [StoredUpdateCount]
Do you know how to solve this issue?
Thank  you in advance
Luis
hchanana
(To:ljam)
Hi @ljam ,
This error occurs when Store and Forward is enabled in KEPServerEX / ThingWorx Kepware Server / ThingWorx Industiral Connectivity(TWIC).
We have a workaround for this which is mentioned in the following article
https://www.ptc.com/en/support/article/CS296010
Himanshu
hchanana
(To:ljam)
Hi @ljam ,
Himanshu
slangley
(To:ljam)
Hi @ljam.
If the previous response provided by Himanshu answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
