Operator Advisor use without Windchill?
RagnarRoestad
7-Bedrock
Is it possible to use Operator Advisor without Windchill?
I'm looking into using OA with Manufacturing Apps for performance monitoring.
I would like to use the framework of OA for:
- Work Orders
- Work Instructions
- BoM
- Personell
- setup of connected tools
- historical data from connected tools
Is this doable without Windchill?
- adding the information manually
- possibly importing some data through cvs or xml files
Does anybody have thoughts or experience doing this?
Are there any guidelines for the implementation work?
Yes you can use Opeartor advisor without windchill as well . Windchill is just the source of data which we are pulling through Odata connector into Thingworx and leveraging Operator Advisor framework to store that data. This data source could be anything other than windchill. As of now there is no guidelines available on the implementation of operator advisor  without windchill but this is doable.
