Hi, Is there any option to restore drawing in my workspace, I checked out the drawing from the server and this overwrote the latest in my local folder (there isn't any warning for that!!!)?
Probably not.
You had file abc.drw in your workspace, revision B.4, which you then modified and saved.
A checkout of abc.drw B.4 should not overwrite what is in your workspace.
Going to the server and doing a checkout of abc.drw B.4 should also not overwrite what is in your workpace.
Doing a download from the server of abc.drw B.4 to your workspace will overwrite the contents of abc.drw in your workspace.
Is this a Model Manager related question ? If yes, and some conditions, there could be some positive answer.
