Annotation Unit change help needed
GP_10708304
2-Explorer
I am using 20.6 Creo Elements direct,  When I am in annotation I can not change from INCH to metric as my default, I've tried changing the units, but they say they are already in MM, I also tried dimension properties but it will revert back to Inch after the selection. Any help would be greatly appreciated.
File-> settings -> Default Settings then go to dimensions text length unit style and change it.
Creo Element\Direct Modeling 20.6.0.0.0
Please, give screenshots of how you change the units.
http://kotom.eng.free.fr
My issue is I can't change to MM units and I need to. I did try system settings but it's already set in MM, the annotation stays in inch. I also tried dimension properties, but it will always revert back to INCH.
Thanks for help, that was the issue!!!
Glad to help
This change will be saved to c:\users\(username)\AppData\Roaming\PTC\Creo Elements Direct Modeling (Version number\Annotation.
in case you want to back it up.
Tom
