Is it possible to put chain dimensions in a set so that they are linked with each other? It's handy when you move one of the dimensions that the other ones also follow.
Kind Regards
SEEBO
I don't think (but I am not sure) that it is possible to do a group of dimensions. But you can move in one shot several dimensions by selecting them with a box or with the SHIFT key.
However, for information, you can group one dimension with several texts.
Hello, moving them with a box is indeed the best solution for now.
Thanks for the help
