Change geo resolution of an imported part
EI_10453429
If i create a part(.pkg) i get a geo resolution of 1.0E-6 mm.
But when i import a part to creo, for example in .step, always get a geo reolution arround 1.6E-2 mm.
The company that i work for as a module that allows me to compare the active part to the database, and returns me the part with more similarity. But this only work if a the part has a geo resolution of 1.0E-6 mm.
Is any way to work arround this? i want to use this module with imported parts, but i cant becouse i have a geo res of 1.6E-2 mm.
Creo Elements Direct 20.2.1.0
hello
 when importing in STEP you have the possibility to choose to change the resolution of import.
see image below.
The higher resolution you have, the more likely you are to have reconstruction errors .
thank you
hello
see image below.
thank you
Thanks!!! It worked!!
