I got a problem with using the positioning function in creo elements direct.
When I use the positioning function, in the dynamic method, I am able to click on a face when the 3D co-pilot appears. In the past I was able to also do this with edges. Click the edge and a co-pilot would appeard so I was able to rotate a part around the edge, or move it along the edge.
Selecting the edge is now not possible anymore. I added my 'catch' settings screenshot, maybe there is a problem with that.
Someone knows what the problem can be or where I can find some 'snap' settings
The issue is not the catch, it is the Ref. Focus, change it to all. See the attached jpg.
Thanks, exactly what I was looking for!
