Creo elements will not start due to connection error and manual activation fails with a 404 not found error
nmarriott
8-Gravel
Tried to start Creo this morning which failed. I have had this before and used manual activation, but when I try this today I get a 404 error (address is https://www.ptc.com/appserver/securePeModeling/peManualLic.jsp?lang=en&u=Niall etc)
How can I start Creo?
45 REPLIES 45
Yep, any Updates ??
Same Problem: Would be great to have a solution quick. Need to do some work urgent!  🙂
Good day all -
We are continuing to work the issue and I will supply updates as I have them.
Sorry for the delay and I appreciate the patience.
Best,
Toby
Good day,
Looks like this is fixed.
Please let me know if any issues remain.
Best,
Toby
Toby,
I can certainly get back onto the manual activation server. Thank you:)
However it is still not license checking automatically, is this still an issue?  Or is there a further step I need to take?
Niall
fhornung
2-Explorer
(To:Tmetcalf)
Hi Toby,
I just tried: I'm back in and everything seems to be going OK, Thanks a lot!!
Fred
Giorgio
2-Explorer
(To:fhornung)
since yesterday 11 April 2018 the problem "Creo elements will not start two to connection error and manual activation fails"
How can the activation problem be resolved?
StephenW
(To:Giorgio)
The most appropriate thing would be to call PTC Tech support. The community can't do much other than give advice.
Good day all,
I will provide updates here
Re: I get no license from ptc server and can't start ptc creo elements - is the ptc server down??
I will lock this discussion to stop duplicate conversations.
Best,
Toby
RXIAOC
6-Contributor
(To:nmarriott)
Sorry guys, this morning I've try to connect but have the same issue as last year, Is the server down again or it's just me?
Got the same problem since a few hours!
Hope it get fixed real quick, because i have a important project running. And just 2 weeks remaining for my degree dissertation in university.
Any tricks to start working again?
StephenW
(To:RXIAOC)
@Jaime_Lee
In the past, Toby has helped Creo Elements Direct users with a PTC license server issue.
See this discussion https://community.ptc.com/t5/Additional-Creo-Questions/I-get-no-license-from-ptc-server-and-can-t-start-ptc-creo/m-p/163816
Seems like a problem on the PTC side has occured again.
Jaime_Lee
Community Manager
(To:StephenW)
Thank you for bringing this to our attention.  I sent this thread to internal Creo teams for review.
Still not working for me . . . has been at least a week or more that an Activation Key pop-up has been happening.  free Elements user
Is there a forecast when a fix will be in place ?
wskmpm
2-Explorer
(To:Jaime_Lee)
Not working now either
HI,  I just started having this problem starting Friday  5/21/2021.    Same exact issue.  Is there a solution for this?
Thanks.
