Excuse me, sir
When I load the PCB, the connectors are like the cubes.
How do I show the real connectors?
Please help check the following pictures.
Respectfully
To do so, you first need to create a library with your desired geometry for each PCB part, and indicate the route for that library,.
You should have a look to the help documentation of the PCB module:
You can also sustitute each part by your desired model when traslating the PCB or individually.
Pedro
Pedro
Thank you, Pedro
I'll try it!😊😊😊
