Hello everyone
Could someone give me instruction how to add frame for inspection dimension in Creo Direct Modeling/Annotation 20.0.
The only possibility I found is to add balloon frame to dimension, but result is not nice and is not work for a single number see picture 1, but wish to have it like a std one see picture 2.
Looks like the command is stripping out any leading/trailing spaces for both the prefix/postfix.
The alternative would be to write a small dialog that would work at the drafting level. Attached is a simple example using the IKIT interface. Copy/paste this into Annotator (or load it from a file) and execute the new command single_digit_balloon. Select the dimension, and a single space will be entered for both the prefix/postfix. There is no real checking going on here, that would require additional effort. steveg
(in-package :docu)
(use-package :oli)
(sd-defdialog 'single_digit_balloon
:variables '(
(DIM :selection s_docu_dimension)
:ok-action '(let (part address curr-part)
(setq part (docu-selitem-pid dim))
(setq address (docu-get-me-ptr dim))
(sd-execute-annotator-command :cmd
(format nil "EDIT_PART '~A' ADD_DIM_PREFIX ' ' POINTER '~A'"
part address))
(format nil "EDIT_PART '~A' ADD_DIM_POSTFIX ' ' POINTER '~A'"
part address))
You could add a prefix and/or postfix to the single digit dimension. If you add a space character, the result would then be oblong and would not impact the value if you later modify the geoemtry in any way.
It helps, but only if i add 2 spaces is not accept 1 space, and result is really ugly.
(in-package :docu)
(use-package :oli)
:variables '(
part address))
part address))
Hello
I push solved before to check the solution, in my case didn't help.
What was the issue with the proposed solution? What did it do on your side?
steveg
Hello
I created a .lsp file in NOTE and inserted inside folder : C:Users\....\AppData\Roaming\PTC\Creo Elements Direct Modeling 20.0\20.0\ANNOTATION\Default_Settings
and after start Creo Elem. nothing changed.
Second step was loaded .lsp file direct to an opened Creo Elem. Software didn't show any warnings or issues.
It is not sufficient to just load the file. As specified in the description, loading the file will create a new command called single_digit_balloon. After you create a balloon dimension with a single digit, execute the command (type it into the command line) single_digit_balloon. This command will prompt you to select a dimension with a balloon and then will automatically add a space to both the prefix and postfix so that the balloon is no longer round. This new command does no verification that the dimension is a single digit dimension.
Thank you for additional comment, it works fine.
you save me 🙂
