so you ask questions here to suggest improvements in reality?
If this is always the case, then it is a waste of time to answer your questions.
Well, maybe it helps someone else, but then you sould mark it as answered, so that it is seen. 🤔
And why don't you take the direct way?
Look at
"Community Creo Ideas Creo Elements/Direct Ideas"
and contribute your creativity there.
But I agree with you. Since the program was taken over from CoCreate by Ptc, it has become a stepchild. ☹️
Correct, there isn't.
But you can use the normal available functions for that.
So make a circular pattern with two features.
Why are you looking for something specific when something else is available?
Hello FriedhelmK
Firstly thank you for your reply.
In fact, I know how to pattern a feature but this is the long way not the real solution. I think, PTC should add new design commands into Direct version. I have been using this program since 2006, and I can not see any useful module since CoCreate version17.
Look at
